12-24-2017 11:55 PM
Hi all,
Wish you Merry Christmas and a Happy New Year 2018!
I am using NI PXIe-1062Q Chasis (connected to a Dell workstation Precision 1700) with the following modules :
1. NI PXIe-8381
2. NI PXI 7851 R
3. NI PXIe-6738
4. NI PXIe-6535
In my workstation, I have plugged in the PCIe-8381 module for connecting NI PXIe-8381 to the computer into a PCI-E Gen 3 x16 slot. Now here is my question :
Q.1. My NI PXI 7851 R card is working when in use it to generate TTL high and low signal. I have made an FPGA VI which has a flat sequence with three frames: to generate a TTL high signal on one DIO channel, then I wait for some time using wait function, and finally I generate a TTL low signal on that DIO channel. All this I can nicely see on an oscilloscope as a TTL rising up and then falling after the wait time.
However, the voltage rise is only 1 volt in contradiction with the datasheet specifications of the 3.3 V which NI PXI 7851 R card should produce. I am using a coupling impedance of 50 Ω in the oscilloscope channel.
Also I was wondering if it is possible to configure the logic levels of NI PXI 7851 R using LabVIEW or MAX. I found some methods online but I am unable to implement them as those options are not shown in my LabVIEW.
Solved! Go to Solution.
12-25-2017 04:33 AM
RRI_user wrote:However, the voltage rise is only 1 volt in contradiction with the datasheet specifications of the 3.3 V which NI PXI 7851 R card should produce. I am using a coupling impedance of 50 Ω in the oscilloscope channel.
Read the data sheet again. There should be a Max current specification for the DIO. It is typically 4mA. 4mA*50 Ohms is 200mV. So change your oscilloscope to the 1M input resistance.
12-27-2017 05:50 AM
Hi crossrulz,
Thanks a lot. It worked. I see a similar requirement of 1 MΩ coupling resistance for AO channels also.
Just out of curiosity, I was wondering how one would explain the 1-volt signal I had seen with 50 Ω. Your calculation says it should be 200 mV.
Thanks anyway!
