Change Printers
At the moment I use the VI Settings, to print a Fontanel. The problem is that it always prints to the standard printer. Now I want print it to different printers. How can I program that a printer selection will come, before it prints?
Thanks! petric
Message 1 of 20
(5,413 Views)
Have you tried ammending the windows default printer to the printer you want ?
chow xseadog
Message 2 of 20
(5,408 Views)
Yes, that's possible, but I don't want change every time the default printer. I have to change it a lot:-)
Message Edited by Petric on 09-20-2005 11:56 AM
Message 3 of 20
(5,405 Views)
You can use property nodes to get a list of available printers and the current default. You can also set the default. This is 7.0 format.
Message 4 of 20
(5,398 Views)
Thanks a lot, but I've LV 6.0.2...
How can I get the property nodes for my Version?
Message Edited by Petric on 09-20-2005 12:42 PM
Message 5 of 20
(5,399 Views)
Message 6 of 20
(5,393 Views)
Unfortunately I'm not able to get the Pr.Printers property nodes all I get are this in the screenshot.
Or have I to add some ActiveX things?
Message 7 of 20
(5,384 Views)
Sorry about that. What operating system are you using??
Message 8 of 20
(5,373 Views)
I use Windows XP Professional.
Message 9 of 20
(5,367 Views)
With v6, you may want to look at using Print Panel to Printer.vi found here [link removed; example no longer available] which allows you to specify a printer or use a dialog.  Not sure how it'll work with XP though.
Message Edited by Donald on 09-20-2005 08:29 AM
Fading out. " ... J. Arthur Rank on gong."
Message 10 of 20
(5,366 Views)
