Change Scan Rate for DAQmx Read functions
I'm using the DAQmx Read functions to read incoming analog signals. I would like to set the scan rate for the DAQmx Read, however I cannot figure out how. Thanks!
(3,631 Views)
not being that familiar with DAQmx i think you use the DAQmx Timing property to set the SampClk.Rate
Dan
(3,630 Views)
Yes you can use DAQmx timing property node, or insert a "DAQmx Timing" VI before you start your acquisition. You can find lots of DAQmx examples in the NI example finder (under LabVIEW menu, go Help/Find Examples).
Dan
(3,630 Views)
Thanks!
(3,630 Views)
