Change Tabbing order within Type Definitions?
How can I change the Tabbing order of Type Definitions? (unfortunately the option in the edit menue is greyed out for type definitions...)
(2,535 Views)
Hi There,
I just found out is wasn'T a problem using Type Defs but using Clusters, and here one can't use the tabbing order option but rather use "reorder controlls in cluster" in the context menue of the cluster...
CHeers, Rainer
(2,532 Views)
