Change USB Raw to Instr
I have done a search but have being unable to find the correct answer.
Basically i have set up a USB Touchscreen device but its visa class is set as ::USB Raw:: .
I need it to be ::Instr::
Is this possible and how do i go about changing this. I am a noob to all this so a clear guide is needed if possible.
Thanks.
(3,119 Views)
The driver from the vendor would define the class and if something is not USBTMC compliant, it is not going to be defined as USB::INSTR. I'm actually surprised it is defined as RAW. I thought touchscreens are defined as HID class. You didn;t so something such as create your own VISA driver using the wizard, did you?
(3,107 Views)
If you could expand a little that would be really useful. The make and model of the touchscreen, whether you are using the vendor driver and maybe a post of your code would be great.
Nick
(3,089 Views)
