Change X axis of a chart
Is there a way to change the X axis of a chart to a user defined variable. I want the chart to be updated in real time showing the time interval between the two sucessive points on the X axis ? Any suggestions.
GM
(2,887 Views)
Look at the shipping examples. There's on called Real Time Chart that shows how you do this.
(2,883 Views)
A chart only holds the Y value for each point and calculates the X value based on an offset and a multiplier (the difference in seconds between each 2 points). If the difference in time between each 2 points is constant, you can create a property node for the chart (In the Application Control palette), wire the start time (as a DBL) into the Offset property and the multiplier into that property. Then, right click the chart, select Format & Precision and select Absolute Time.
If the difference is subject to change, here is a VI that goes along the lines of the example Dennis mentioned.
___________________
Try to take over the world!
(2,872 Views)
Reply # 71 of this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=133548#M133548
Has an llb in whichyou will find a VI called Beer Monitor2. Youwill have to download the llb.
It show you how to use a waveform data type to get a chart to to do non periodic updates.
Ben
Message Edited by Ben on 07-30-2005 08:11 PM
(2,864 Views)
