Change a 2D Array into a 1D Array.
In this vi, I would like to change the 2D "Y array"
into a 1D array. The 2D Array has 50 (amplitudes) times 60 (times) elements. I have tried with the Reshape Array, using the constant 1 for the dimension size or the Transpose 2D Array, but it does not work.
Summer
(3,505 Views)
hi
find one possible solution attached
regards
wha
(3,505 Views)
Hi
Many, many thanks
best regards
Summer
(3,505 Views)
