Change address number to Beckhoff ethercat slaves in LabVIEW project
We will probably never add any solution to this problem for project based discovery because ECAT uses Position addressing and not node IDs that would be slave assigned.
The solution for this problem would be to use the programmatic approach of discovering and deploying network setups.
This way you could make whatever change you want to your network and just discover and deploy again programmatically.
DirkW
Message 11 of 13
(980 Views)
OK. Not so great news. Is there a way to discover and deploy programmatically EtherCAT network? As far as I know all network configuration can be done only from project explorer. Please, prove me that I am wrong 😉
Message 12 of 13
(970 Views)
Hey Jurpe,
I believe the information from http://digital.ni.com/public.nsf/allkb/FDC87938F1191A3C862578FF00757270?OpenDocument
it will be useful for you.
Kind regards,
Message 13 of 13
(960 Views)
