Change an existing controls style
I'm in the process of upgrading a large application from LV 8 to 2011. I would also like to update the UI to use the System control style instead of Classic, which is the current style. Is there a way of modifying a controls style without having to right-click on each control, selecting Replace, and then the control you want?
(6,734 Views)
(6,713 Views)
I got a script started for you. For the script, you just need to do duplicate case for each type of controls that you want to modify.  I already did the numeric and string cases for you.
Kudos and Accepted as Solution are welcome!
(6,707 Views)
Your utility works nicely! Thank you.
(6,693 Views)
For the Style's property node in your script, there is a Values[] property.  Can you tell me how you create it?  I can't find that property.
(6,685 Views)
