Change analog input range of PCI 6110
The analog signal that I want to measure is 24 Volt and the maximum of PCI 6110 is 42 Volt.However, the analog input range that display in configuring device under Traditional NI-DAQ (Legacy)Device is 10Volt (the only one selection). I am using LabView 7.1,DAQmx 8.6 and there is no function to let me to modify and change the analog input range of the device (please find the print screen from the attachment). May I know how can I change the analog input range?
(3,200 Views)
Accepted by topic author 109865
I think this is what you're looking for:
 How Do I Configure an S Series DAQ Board for the Full Input Range So It Does Not Clip?
You have to set up an appropriate gain in order for other voltage ranges to show up.
By the way, you may want to post to the DAQ forum instead of Labview in the future, as chances are you'll get better/faster answers there 😉
Good luck!
Misha
(3,149 Views)
Thank you very much,Misha. It is very helpful infomation from you. I will try to connect to my sensor and check it again. Thank you again. 😃
Sue
(3,120 Views)
