Change back color
Having trouble changing the back color of cluster 2 in the example.
Th last color is the only one that displays.
I would like to have:
Array index 1 cluster 2 back color equal color array index 1
Array index 2 cluster 2 back color equal color array index 2
etc.
LV8.2
(3,575 Views)
The way you're currently doing it is changing the color of all the values for each iteration of the loop.
I'll have a look at how to implement what you want tomorrow as it's home time here in the UK!
Sarah
Applications Engineer | National Instruments | UK & Ireland
(3,566 Views)
You end up with an array of identical clusters.
All elements in an array must be indentical except for their values.
Cosmetics cannot vary on an element basis!
As a workaround, you could e.g. add a colorbox indicator behid the numeric inside cluster 2 to get the desired effect. See attached modification (LabVIEW 8.2).
(3,556 Views)
