Change clock rate of HWS waveform
I'm generating waveforms using an HWS file on a PXI-6541 (using LabView 8.2).  I'd like to be able to pause the waveform, change the Sample clock rate, then resume.  Is that possible?  I currently abort the waveform, change Sample Clock Rate, then re-initiate, but I lose my position in the waveform by having to start over.
(2,492 Views)
Hello SirMutt,
I posted a response to the same question that you asked on this forum.  Please post further High Speed Digital I/O questions in the appropriate forum.
Thank you,
Message Edited by Raajit L on 04-24-2007 10:36 AM
Raajit L
(2,464 Views)
