Change color of disabled button
how can i change the color of a "diabled and greyed" button? I customized the button with new pictures for the true and false-state. but when the button is disabled and greyed then its always the same color: grey.
Is it possible to change this color somehow?
Thx for oyur help
Message 1 of 8
(4,117 Views)
If you set the enabled state property to "diabled and greyed", it's greyed Smiley Happy
But you can also set it to "disabled" instead. This won't grey out the control.
Message 2 of 8
(4,108 Views)
Thanks for that hint. That solves my first problem.
Second question is: Why is the color property sometimes not available?
In my example i have a cluster with OK-buttons and create a reference to the cluster. The i want to change the color of the first cluster-element. But the property color is not available.
The problem is not the reference. When i do the same with only one button (and no cluster) then it works.
Any idea how to solve this?
Message 3 of 8
(4,099 Views)
The problem is the reference. The 'Controls[]' property of the cluster outputs an array of general control references. To use these you have to cast them to the right type so you can use them like you want.
My LabVIEW Ideas
Message 4 of 8
(4,096 Views)
The problem is the reference. The 'Controls[]' property of the cluster outputs an array of general control references. To use these you have to cast them to the right type so you can use them like you want:
Ton
Message Edited by TonP on 09-26-2006 04:10 PM
My LabVIEW Ideas
Message 5 of 8
(4,097 Views)
Hello TonP,
thank you very much for this ultra-fast solution of my problem.
Works perfect.
Message 6 of 8
(4,084 Views)
Hmm, one more thing. I can connect now the color-property but i get an error (1055) and the color is not changing.
See attached picture.
Message 7 of 8
(4,076 Views)
Edit: Forget my last post.... *g* i connected the wrong wires together. It works.
Message 8 of 8
(4,073 Views)
