Change color of indicator
I am struggling to change the indicator color based on user button selection. Can someone help me? I need to save the color as well but don't know how to connect all.
(6,033 Views)
Use the property Named Colors, and feed the values based on the selection of color you Need.
You can use color box constant to feed the color based on your switch selection
(6,026 Views)
That's what I did. But I am not getting it right.
(6,023 Views)
Hope this helps you!
(6,016 Views)
I understand how that works. I just want to connect what I have already and know how to.
(6,005 Views)
Accepted by BArtzon
Then use "bundle" and "build array":
Regards, Jens
Kudos are welcome...
(5,976 Views)
Perfect. Do you know anything about the save boolean? How would you save each image when you press "save led image"?
(5,971 Views)
