Change color of indicator
I am struggling to change the indicator color based on user button selection. Can someone help me? I need to save the color as well but don't know how to connect all.
(6,031 Views)
Use the property Named Colors, and feed the values based on the selection of color you Need.
You can use color box constant to feed the color based on your switch selection
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(6,024 Views)
That's what I did. But I am not getting it right.
(6,021 Views)
Hope this helps you!
(6,014 Views)
I understand how that works. I just want to connect what I have already and know how to.
(6,003 Views)
Accepted by topic author BArtzon
Then use "bundle" and "build array":
Regards, Jens
Kudos are welcome...
(5,974 Views)
Perfect. Do you know anything about the save boolean? How would you save each image when you press "save led image"?
(5,969 Views)
