Change color on a control
Hello Everybody,
I'm new to this and my question is like this:
I want to change the background color on a control between two colors depending
if a value is greater then a set value. In this case the backround should change from white to red
on a RPM meter when the RPM is greater then the RPM limit.
I found out how to set the color using the property for the control but I can't figure out how to change
between the two colors using a comperisson function.
Thanks in advance!
Regards
Roger
(3,138 Views)
Please see the attached vi, I believe that it will accomplish what you are after.  Please let me know if either it does not work or you have any questions.
Cheers!
(3,131 Views)
Also have a look at this thread: http://forums.ni.com/ni/board/message?board.id=170&message.id=308308
There may be some interesting suggestions.
(3,125 Views)
Thanks for your help!
Unfurtunally I couldn't open the example because I'm running version 8.0. I'm not
sure if it's possible to convert it to an older version or not.
//Roger
(3,103 Views)
Here's a screenshot of the code, you should be able to implement it.
Ton
Message Edited by TonP on 03-14-2008 11:31 AM
My LabVIEW Ideas
(3,099 Views)
Thanks Ton!
I'll try this.
Roger
(3,085 Views)
