Change counter input USB-6211
Situation:  I have 3 signals I want to measure using counters on my USB-6211.  Since the 6211 only has 2 counters I was planning to measure them seperately and just switch which PFI was the input depending on which signal I wanted to measure.  However, when running the VI only PFI0 and PFI2 detect anything.  If I connect to any other PFI the Read times out.
From other forum posts and my Device routes in NI MAX it says I should be able to internally route PFI0-3 to any of the CTR inputs so what am I missing here?
Thanks!
Wyatt
(2,675 Views)
This is no longer an issue. I copied the code into my main VI and created a new SubVI and it is now functioning properly... not sure what changed when I copied it though.
(2,664 Views)
