Change icon in Windows Taskbar
Good morning to everyone,
i try to explain my problem.
Is possible to change the executable (.exe) icon in Windows taskbar using LabVIEW code?
Is there any methods or trick to change the taskbar icon, using a different icon from the icon used in
the application builder?
Thank you.
(4,452 Views)
(4,443 Views)
Hi, any chance anyone have the VI in that link? looks like it's not there anymore.
(3,799 Views)
https://forums.ni.com/t5/LabVIEW/Changing-Icon-in-LabVIEW-Title-bar-of-a-vi/m-p/1480986#M560223
This seems to be the essential code. Needs some editing if you want to use this in 64-bit LabVIEW.
Rolf Kalbermatter  My Blog
(3,793 Views)
It's still there.  Are you logged into your LAVA account?  The post Rolfk provided is essentially the same thing as what is posted on LAVA.
(3,769 Views)
Thanks for the help, I was not logged into LAVA. I used Rolfk link and that also worked for my application, thanks again!
(3,741 Views)
