Change justify and style of cells in table
I'd like change it. My table change of size in runtime because I can not make it manual.
(2,749 Views)
I don't know exactly what you are looking for but it is possible to change the size of table elements like column with or rowheight and save is as default for a table.
(2,746 Views)
You can access the cell size by using Property Nodes. Just right-click on the table control on your block diagram and go to Create >> Property Node. Then left-click on the property and select Cell Size to get either width, height, or a cluster containing both. Hope this helps!
Jeremy L.
Jeremy L.
(2,733 Views)
