Change language of time/date browse button
Hi. How I can change the language of time/date browse button. For example,
i want to change the caption of button "Set time to Now", to the "Time"? Is it possible?
Thanx.
(3,326 Views)
Hi rusl,
Are you currently using a language version of LabVIEW other than English?
Do you want to change the language (i.e. from English to another language) of the buttons in that dialog box or just the text? You mentioned that you want to change the caption of the button, but this is a different challenge from changing the language of those buttons.
James D.
(3,291 Views)
Hi James-D,
I use English version of LabVIEW, but my OS is Russian. Yes, I want change language of the buttins, but also want to know, is it possible to change text of button.
So, does anybody know answer to any questions?
P.S. I didn`t understand, why wriiten "Московская время (зима)" in Russian language, but buttons in English?
(3,282 Views)
Accepted by topic author rusl
The dialog is a VI that is part of the LabVIEW package.
You can make a copy of this VI and edit the button text as you want.
look for picktime.vi in your \resource\dialog\ subdirectory of your LabVIEW installation.
(3,270 Views)
Thanks a lot
(3,250 Views)
