Change major grid thickness
I use xy graph and I need to change major grid thickness (thicken)
How can I change major grid thickness ?
(2,828 Views)
Accepted by topic author s.zahedinejad
You can't change the thickness.  Change the color instead so the grid is either less noticeable or more noticeable.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,798 Views)
The work around is to disable showing the cartesian grid and put your own image of a graph in the middle plot image
(2,791 Views)
thanks for your information
(2,769 Views)
