Change name of graph[label-property node]
I would like names from "check box"(cluster) that will appears as label(name) on graphs, like on picture; I try to implement this with property plot->plot name; but always was problem that is not working or it's show error that I cannot change this while is running my program; Program is attached.
_________________________
Rookie; LV 2011 on WIN 7
(5,188 Views)
From your picture it looks like you want to change the label. You can't change this during runtime. Hide the label and show the caption, then modify the caption (property Caption > Text).
(5,182 Views)
Ok I do this, but now I have problem what to connect to "Caption.text". I have cluster, but "caption.text" need "string";
(5,180 Views)
Accepted by topic author hlod
You have to extract the labels of the controls in the cluster. See attached snippet.
Cluster-labels to wv cp
(5,177 Views)
Thank you, it's working 😉
(5,172 Views)
