Change new VI Default Icon?
Is this post still relevant to the latest version of LabVIEW (2012):
http://forums.ni.com/t5/LabVIEW/change-default-icon-for-new-VI/m-p/448064
Or is there a better way/more preferred method?  It would be nice to change up a bit.
Thanks.
(5,316 Views)
What's wrong with Ton's suggestion - use the lv_new_vi.vi callback to override the New VI command and make a copy of your own template?
___________________
Try to take over the world!
(5,293 Views)
I guess the easiest solution is to save a preferrec icon as Glyph in the icon editor to get a good starting point. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,285 Views)
Who is Ton and where is his suggestion?  I don't see it in the link I provided.  I asked because the thread was from 2006, and was wondering if there was a better solution available.
It looks like a good solution to use a template, but then again it would be nice if the default icon was changed when selecting parts of a block diagram and going to "Create SubVI from Selection".
(5,257 Views)
Ton is TCPlomp.  His suggestion is here:http://forums.ni.com/t5/LabVIEW/change-default-icon-for-new-VI/m-p/448115#M218003
(5,252 Views)
Since 2011, LV has a VI-based process for creating a subVI from a selection. You can put your own code into that process. Look at <LabVIEW>\resource\plugins\CreateSubVI\Additional Actions Template.vi
You can set the VI's icon to a new image using a method on the VI, but I believe 2011 doesn't allow you to build an icon from layers like the icon editor does. My understanding is that 2012 is supposed to have an API to the editor which might allow you to do that.
___________________
(5,232 Views)
