09-16-2005 08:31 AM
09-16-2005 11:36 AM
05-23-2007 02:09 PM
11-23-2012 02:48 PM
Hi Oliver. I saw your SetFileTime.vi on the German LV site. I was writing my own but have encountered some errors. Your vi is in 8.0 and I have LV2010-2012 but they are not installed. I use LV6.1 and don't want to install LV2012 because I want to keep my machines "clean" as I will be soon doing an installation test of my own LV app. I wondered if you could send me a couple png's of the BD and of the Call Library Node configuration please. That would help me a lot.
11-23-2012 02:56 PM
Oliver has not logged onto the Forum for almost five years.
Lynn
11-23-2012 03:17 PM
11-23-2012 11:19 PM
Thanks guys, I'll try that.
12-07-2012 01:45 PM
Here are updated versions in LV6.1. You can set the Creation, Access or Modification Date with a cluster or LV seconds (U32) in UTC or local time.
12-07-2012 04:34 PM
I changed the Generic acces rights from GENERIC_ALL TO GENERIC READ | GENERIC WRITE because I was getting errors over a network. Here are the final versions.
12-08-2012 08:59 AM - edited 12-08-2012 09:02 AM
@Oliver Frank wrote:
The "G Toolbox" is a commercial product and wasn't a choice also the OpenG Toolkit they change there license away from LGPL.
What could the issue be from changing from LGPL to BSD? If anything BSD is much more permissible. It "only" lacks the requirment to seperate the VIs out of a build executable when you want to distribute said executable. ![]()
