Change port used to send SMTP e-mail
I am trying to send e-mail notifications using a .vi.  My company has blocked SMTP port 25  to prevent SPAM.  My IT has told me that there is another port I can use to send e-mail.  It is possible for me to change, IN LABVIEW, the port used to send e-mail?
Thank you.
(3,914 Views)
Without modifying NI's SMTP library the answer is no. The port they use (25, standard SMTP port) is hardcoded in their library.
Message Edited by Mark Yedinak on 09-15-2009 10:31 AM
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,911 Views)
For future inquiries, if you drop the Send Email.vi from the smtp email group and right-click, then open front panel, you can pull the subSendEmail.vi from the block diagram that will give you all the options the wizard has.
(3,406 Views)
Probably the easieist way is to use stunnel.  It can intercept email trying to go out that port and send it to one that you specify.  It can even do SSL for you, so it's great for old programs that only know how to send unencrypted email to port 25 (or lazy LabVIEW programmers).
Bill
CLD
(Mid-Level minion.)
(3,398 Views)
simply append the port number to the server address, divided by a colon, for example:
smtp.gmail.com:587
Bye
m
(1,775 Views)
