Change size of an object in an array
I have a cluster of elements in an array that is set to scale with window size.
When I'm running my vi, I only need 3 < n < 15 elements visible at any given time. Is there a way I can change the size of the elements in an array so that they grow in size to adjust with the window?
Message 1 of 9
(4,951 Views)
Size of the elements or the number of elements ?
To change the number of elements shown, there is a property node for that.
Message 2 of 9
(4,926 Views)
I'm looking to change the size of the elements. If there were n=12 each element would be 100x100 pixels but if there are n=6, each element becomes 200 x 200
Message 3 of 9
(4,914 Views)
You need to post a VI that shows what your elements are.
Some elements such as numerics can't have their height changed.
For things that can, you can use property nodes of those elements to set the height.
Message 4 of 9
(4,911 Views)
Ahh
I'm looking to scale this control (or Something that has a similar amount of data)
Message 5 of 9
(4,889 Views)
Accepted by topic author ATE-EGNE
Try this example.
For some reason your control is part of a class library.  I had to break that to be able to work with it.
Message 6 of 9
(4,881 Views)
Thnaks! That's what I'm looking for (I was messing around in the bounds area by mistake)
Message 7 of 9
(4,874 Views)
That would make sense, but those are read only properties.
What I posted seemed to work, even with the controls inside a sub-cluster.  But I think it is because the cluster containers are set to auto-size.
Message 8 of 9
(4,870 Views)
Yes it does work, There's going to be a bit of data hiding involved before it gets to my top-level vi, but I can take care of that. Thanks for your help.
Message 9 of 9
(4,864 Views)
