Change string positions. (LSB to MSB)
I need to reverse the position of an String (where its values will be between 0\ to 999\, max 4 characters), for example :
If I have a string control where I write ( 123\ ) , I want to display (\321).
If I write (12\), I want to display (\21).
If I write ( 1\ ), I want to display (\1).
Im trying to use the Rotate String function, but it only rotate like this :
123\ -----> 12\3
12\ -----> 1\2
1\ ------>\1
(I just wired my control to the Rotate function and wired the output to an Indicator)
How can I apply the reversion correctly ?
Kind regards,
(3,772 Views)
Reverse String…
(3,770 Views)
If only it was in the name of the function .....
Smiley Surprised  Smiley Very Happy
(3,753 Views)
and if only it was right next to the function the OP is already using in the palettes...
(3,749 Views)
