Change table precision in express vi
Hello friends.
I have a problem.
I uses an Express VI to build a Table.
If you see an example below, it shows a table with precision set at 2.
Now if I want to change the precision, I have to right click, go to properties and do the precision change.
Is there a way to change the precision programatically. I couldnot see any property node for the precision setting.
Can anyone help me ?
PS: I am not very very conversant with Labview yet, so I would like to stick to Express VIs. I know they are not preferred by senior programmers but they are somehow very easy and convenient to use for newbies like me.
Rgds,
Rohit Chawla.
(2,922 Views)
No, there is no programmatic way to do that. Express VIs are front-ends to actual VIs. That's what you get for simplicity - limited functionality
(2,913 Views)
Accepted by topic author Rohit_Chawla
Not possible in Express VI itself, but you can add your own code between the Express VI and the resulting table. See the attached modified VI to get the idea.
Cheers,
Cerati
(2,907 Views)
Thanks Smercurio_fc and Cerati
(2,898 Views)
I came across the same issue. I would think that the developers of Express VI's would anticipate having property node inputs for the things (common, not necessarily all) in the Configuration Dialog. Just my 2 cents!
(1,021 Views)
