Change the Default Page in LabVIEW Web Services
Hello all,
Is there any way to change the default page of a labview web service from index.html to something else? I am trying to host a multi-lingual website, and in some cases, I want to load the index_es.html instead of index.html. Any suggestion is welcome.
Soheyl
(3,153 Views)
Hey  SoheylV,
I am assuming you are using the english version of LabVIEW, is that correct?
(3,075 Views)
Given that assumption, what would your advice be?
(3,060 Views)
Hey SoheylV,
I was thinking you may be able to download another version of LabVIEW that is in the other language you are trying to deploy the web service in. There may be a bit of a process involved though in converting the code to the other language because LabVIEW does not have any translation software.
The reason I suggest this route is that I have not been able to find a way to change the index.html to index_es.html.
(3,047 Views)
