Change the key focus index of a table
I need to get and set the key focus index of a cluster table (without using Tab).
Nice day 😊 !
(1,780 Views)
  1. Explain what "key focus index of a cluster table" actually means.
  2. Attach some simple code.
  3. Explain what you are actually trying to do in simple terms (What does the user see? What's the purpose?, etc.)
(1,760 Views)
Ah, you posted the same in French here and actually attached a VI.
So a "cluster table" is apparently a 1D array of clusters. Who would have guessed?
It is still not clear what you are trying to do.
(1,754 Views)
Also wandering what a cluster table is...
For now, my best guess:
This gives the 2nd control key focus.
You can also right click the control in a cluster, and create a reference to it:
(1,750 Views)
Accepted by topic author Naunaut
I was afraid 'table' meant 'array'...
I don't think there's a decent way to give focus to a specific array element, array elements being clusters won't make it easier.
There might be hacks that allow it, but you're probably rowing against the stream.
(1,747 Views)
The purpose is to work with a 1D array of cluster without using the mouse.
So in a first step, i try to change the focus element of my 1D array.
(1,736 Views)
Okay wiebe,
I will try with an other solution.
(1,733 Views)
