Change value on a wire
Is there a way to change the value on a wire while debugging a VI?
thanks,
jvh
(3,704 Views)
You could replace the wire with a control or a constant.  Other than that I believe you can only probe the wire to get its value.
(3,697 Views)
(3,673 Views)
thanks,
jvh
I have not concidered that since the days of DBG!
It would be hard to implement since wires can fork and be processed in an order you may not expect.
Ben
(3,671 Views)
You cannot change the value on the wire once the VI is running.
You may wish to vote for this idea: Allow Data in Wires to be Forced During Development.
EDIT: I see everybody is on a lunch break? Smiley Very Happy
Message Edited by smercurio_fc on 05-25-2010 12:07 PM
(3,669 Views)
