Change vit file icon
Hello.
I want change vit files icon.I can change vi files icon with "SetWindowIcon.vi" you can see in attachment.
But its not working on vit files.
How can i fix this problem.
Thanks.
(2,867 Views)
I'm not sure how it is inteded to work, but you may need to open a reference to the actual template VI, not the clone that the "This VI" is refering to.  If you open that OpenG function you'll see that it uses the operion 0x2 which opens the template VI, not the clones it makes.
(2,843 Views)
