Change whether tabs are embossed or not
Is there a way to change whether the tabs appear embossed?
(2,585 Views)
I don't have LV in front of me, but here are some options, in rising order of difficulty:
  1. Use the tab control from the classic palette.
  2. Use the tab control from the system palette.
  3. Right click the tab control and select Advanced>>Customize, then click the wrench and see if the tabs themselves can be edited (probably not).
  4. Hide the tabs and create your own. The easiest is probably to use a radio button control and replace the internal booleans with flat buttons.
___________________
Try to take over the world!
(2,567 Views)
Which tab control are you using (Modern, System, Classic)? Like tst said, the easiest ways will probably be to use a tab control from another palette or customizing the control.
(2,553 Views)
