Changes To Be Made From LabVIEW 7 VI To 11 VI
Thanks a lot Norbert!
Your suggestion helped me to explore through different nodes to finally
come up with a solution.
Here is the solution VI attached that works in LabVIEW-11.
But can you help me in my other post(consider this VI instead of that)?The link is here:
http://forums.ni.com/t5/LabVIEW/To-Construct-An-Array-Of-Smaller-Holograms-From-A-Bigger-One/td-p/21...
Thanks!
Message 11 of 11
(417 Views)
