Changes in Labview.lib between 6.0.2 and 6.1 ?
I recently installed 6.1 and tried to run out test system. The error DSPtrAndHand occured in Labview.lib and lv was shut down. I looked at the labview.lib files both in 6.0.2 and 6.1 and the lib file was twice as big in 6.0.2. I am not an expert on the system but i think that we have an external code that calls the function DSPtrAndHand which seems to be some kind of memcopy. This function seems to have disappeared in 6.1. We have tried to recompile with the new labview.lib and the linker warns that DSPtrAndHand cannot be found.
Br
Johan N
(2,698 Views)
Yes, this function has disappeared in LabVIEW 6.1. I'm not sure as to
the reason and considering that it was documented in the CIN Reference
Manual in earlier versions, I was rather surprised to see
that.
However the workaround is quite simple by creating your own function to
do that particular operation:
MgErr DSPtrAndHand(UPtr p, UHandle h, int32 size)
MgErr err;
int32 len;
if (!h || !*h || !p || !size)
return mgArgErr;
len = DSGetHandleSize(h);
err = DSSetHandleSize(h, size + len);
if (!err)
MoveBlock(p, *h + len, size);
return noErr;
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,698 Views)
Hello!
I see that you have already received a good answer but would like to add some information regarding this. You can read about the changes between 6.0 and 6.1 in the following two links:
Error When Calling a CIN from LabVIEW 6.0: No Prototype Exists
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/3a0ab1d4b1a3c2d1862569af00699922?OpenDocument
Why Can't I Use the CIN Example that Shows How to Handle Clusters in the Using External Code in LabVIEW manual?
http://digital.ni.com/public.nsf/websearch/BBBCF3FFF0158DA186256AC7007BC782?OpenDocument
Jimmie A.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,698 Views)
RolfK wrote:
Just one correction:
> MgErr err;
> int32 len;
> return mgArgErr;
> if (!err)
Replace this line
> return noErr;
with
return err;
Rolf Kalbermatter
(2,698 Views)
