Changes made to the driver VIs in Simulation Interface Toolkit (SIT) are not getting reflected
Hi there,
I am using Simulation Interface Toolkit to target a controller built in Simulink on a PXI target. I have used the SIT Connection Manager to generate the driver VIs. I needed to make some changes in the driver VIs specifically the  IO Read.vi . I have made the changes and the whole application runs without error. But the changes are not getting reflected in functioning of the the application, basically when I load the thing on PXI and run it, it behaves exactly the same as it was behaiving before I made those changes. Some how the changes that I am making to the IO Read.vi are not begin updated somewhere in the top level driver vi.
Could anybody please help me with this.
Vicku.
(3,514 Views)
Could you post your code or an image of what exactly you changed?
(3,503 Views)
Accepted by topic author Vicku
Hi Bill,
Thank you much for looking into this. The problem got solved.
The problem was that each time one makes a change one of the driver VIs that top level driver VI has to be opened and saved again. This opening and saving links the driver with new changed VI properly and then every thing runs fine.
Thanks again.
Vicku.
(3,484 Views)
