Changing BG color on a tank digital display
Can't get this to work.
Easy to change the tank fill color and tank caption colors by creating a
couple of property nodes and changing the properties.
But I'm stuck on the Digital Display (the reading, like 123.45) BG color -
where does that get changed?
(2,749 Views)
Note: The following is valid for LabVIEW 6.
In the panel: Make sure the tank's digital display is visible. Right-click the digital display and select "Create -> Property Node"
In the diagram: In the property node, select the property "Numeric Text -> Text Colors -> BG Color"
Check the attached file.
Best regards.
www.vartortech.com
(2,749 Views)
Just to mention that I find out that the answer is also valid for LabVIEW 5.
www.vartortech.com
(2,749 Views)
