Note: The following is valid for LabVIEW 6.
In the panel: Make sure the tank's digital display is visible. Right-click the digital display and select "Create -> Property Node"
In the diagram: In the property node, select the property "Numeric Text -> Text Colors -> BG Color"
Check the attached file.
Best regards.
www.vartortech.com
