Changing Button States in LabVIEW 8.0
I am trying to write a program for a class and have run into a problem.  The requirement I have is this:
I have two buttons (okay boolean button) on the screen, only one of which can be on at a time.  So if Button 1 is true and then Button 2 is pressed, I need Button 1 to turn off automatically without clicking it.  Same things goes the other way, if Button 2 is true and then Button 1 is pressed, Button 2 has to go to false.  I'm still new at LabVIEW so I don't know everything that can be done but I tried working with the property nodes and couldn't find anything that seemed like it would work.  Does anyone has a suggestion as to how this can be done?  Any suggestion would be helpful for this beginner.
(3,325 Views)
Easiest way is with a "Radio button", but you can also do it using the event structure. I've attached a really simple example, probably some more elegant methods,but it is 2 in the morning here (I have been working on a project) and I'm going to bed soon!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,320 Views)
Why dont you try and use an event case.pls find the attached code for reference.
(3,318 Views)
Thanks for the information from both of you!  Both will help out in getting this part of the project finished.  Thanks!
(3,305 Views)
