Changing Faster Sampling Rate using SPI and I2C Driver API
Hello all,
I currently own cRIO and NI 9401 module.
Using the SPI Driver API from here: https://www.ni.com/en/support/downloads/tools-network/download.spi-and-i2c-driver-api.html,
I was able to read the data using the example code.
Now I am trying to read the data at a rate of 1kHz but I cannot change the sampling rate to achive that rate.
I need to read in 128 bits (16 bytes) of serial data at once.
What I tried is to change the clock rate value on configuration but it wasn't successful.
Thanks in advance.
(3,396 Views)
Is the current rate higher but you're finding that you're unable to lower the rate, or vice versa? How have you been trying to change the rate? Could you clarify what you mean by it wasn't successful? Are you getting an error when trying to change the rate or does it just get coerced to another value? If so, what is that value? It might be useful to see the VI that you're using for your SPI application.
Eden K
(3,311 Views)
