Changing File path for different TIFF files in a For loop
Hi dear users:
I am using "IMAQ write TIFF File.vi" that basically writes a TIFF file to a specified file path. However, I would like to CHANGE the file path for each TIFF file i save in a for loop. The reason for this is that the File path has to include the file name and I do not want to write over the same file name all the time in a for loop. What I would like to have are sequential TIFF images. So if the file name would be "Image", I would like the result to be Image0, Image1, Image2 and so forth when I run my For loop. Can anyone help me with this?
(2,979 Views)
Use the "Format Into String" and the "Build Path" functions:
Message Edited by smercurio_fc on 06-26-2007 05:16 PM
(2,966 Views)
Thank you so much! It works perfectly fine Smiley Very Happy
Cheers
Message Edited by NI_User_77 on 06-26-2007 05:47 PM
(2,957 Views)
