I am building an application which uses NI hypertrend. I am having trouble in increasing the font size of the numbers displayed on the time axis as well as on the top where it shows the current time. Since its an Active X control I couldn't highlight the numbers and then change the font size. I couldn't do it programattically also. I want the numbers to appear atleast two points higher than what they are. The only option I had was to reduce my screen resolution . I would appreciate it if someone could me with this. By the way I am using LabVIEW7.1 DSC module
