Changing Graph Scale
One of my programs (LV7.1) will not the operator right-click and change items on a couple of graphs. I have tried deleting and replacing the graphs but it didn't help. One is a waveform chart and the other is an XY graph that displays data at the end of a test. Am I missing a setting somewhere? I have never encountered this before and use graphs all the time. Thanks in advance.
(3,672 Views)
Just found it! Allow Run-time shortcuts was unchecked. Thanks anyway.
(3,664 Views)
Could you create a simplified version of the faulty vi ? Try to remove as much as you can, and see if the problem persists. If so, send the vi. Somebody will find a way out...
Chilly Charly    (aka CC)
(3,665 Views)
Your post title talks about changing scales, but the post talks about changing "items".
Could you post in more detail exactly what you want to change and how you are trying to do it. A small example would also help. 🙂
What kind of data is fed to the graph?
(3,661 Views)
Thanks for your reply but I found the solution about 30-seconds after I posted! I hate when that happens. Allow run-time shortcuts was unchecked under the VI options.
Thanks again.
(3,644 Views)
As I just replied to chilly charly...
Thanks again to both of you for such quick responses!
(3,642 Views)
