Changing Icon in LabVIEW Title bar of a '.vi'
  I reopen this topic 'cause I have the same request.
So the situation is:
I have a main VI that launch two instances of a same subVI to control 2 different machines that makes similar things
I need them to have different icon to have an easiest view of them in the application bar.
I've tried the snippet code and it works correctly with a VI in development mode, but if I place the same code in an executable it gives me a .NET error and it crash immediatelly.
Message 21 of 23
(1,351 Views)
This method works just fine in source or EXE for multiple VIs, or the same VI set to reentrant.  Here is a post I made which has a project that demonstrates having multiple windows set to different icons at edit time, but this also works in an EXE.  There is extra code in that project to detect when a window is dragged from one monitor to another, and it will quickly hide and show that window to get around a Windows 10 (or LabVIEW) bug with the taskbar.
Message 22 of 23
(1,338 Views)
I can't do nothing else but CONFIRM, IT WORKS!
Thank you so much!
Message 23 of 23
(1,327 Views)
