Changing Multiple STL Mesh Color dynamically
I'm developing a VI (attached below) which loads multiple STL files into a 3D picture Control. I want to able to control each STL mesh's color individually at runtime i.e. dynamically. In the present VI that I have posted, I can change the color of the Mesh last created ("Skull" in my VI) dynamically. This is achieved by the SceneMesh. SetMeshParameters method inside the while loop. However, I can't seem to figure out a way to do this to all the meshes. The solution seems trivial. Any help would be appreciated.
Biswarup
Dept of EE, IIT Madras
(3,373 Views)
Accepted by topic author MustIHaveAnAlias
Nevermind, I was able to fiure it out myself. Smiley Very Happy . The solution wa indeed trivial.
Instead of passing the last element of the Mesh ref Nums from the for loop, I passed the entire array and used the array index function to pick the mesh to manipualte as shown above. I have attached the updated VI as well. Hope this helps.
Biswarup
(3,352 Views)
