Changing Number background color
Sorry for asking such a dumb question, why can't I make my number
background green. I've tried every combination of properties and can't
seem to get it to work. See my enclosed vi.
Message 1 of 10
(5,590 Views)
Accepted by topic author Ben_01880
Text is in a CONTAINER, which has its own properties.
You are setting the background color of the CONTAINER.
The property you want is Numeric Text - Text Colors - BGcolor.
Not Numeric Text - Colors - BGColor.
Steve Bird
Culverson.com
LinkedIn
Message 2 of 10
(5,588 Views)
Well This is what I did.
New Vi
Placed an integer indicator on FP, not a container.
Thats it.
Message 3 of 10
(5,582 Views)
That worked.
I don't know why it was called a container ?
Message 4 of 10
(5,577 Views)
CONTAINER is my word not NI's
In general, anything that displays characters of text has a text container - it's an object within the object.
The container doesn't have anything to do with the indicator being a STRING or a NUMERIC, or a TABLE, or a whatever.
It's sole purpose in life is to display text.
A STRING indicator will own one, a NUMERIC control will own one, a TABLE might own a bunch of them.
That is so that all text containers can be treated alike by all methods and properties that pertain to text.
And thus, it has its own set of properties.
Note that the TEXT has a complete submenu of its own, including a REFERENCE?
That means you can pass a reference to a text container around to various VIs and they don't know (or care) whether that text is in a STRING indicator or a NUMERIC control, or a Label, or what.  Anything you can do to text on a panel, they can do it without regard to where it is.
Steve Bird
Culverson.com
LinkedIn
Message 5 of 10
(5,570 Views)
If you look at a NUMERIC's property list, you don't see TEXT, you see NUMERIC text.
This is a child object (I'm guessing here, I have no internal knowledge) of the TEXT container.
YOu can set the NUMERIC TEXT : TEXT property, and the value of the control reflects it.
I've been wanting a way to blank a numeric indicator, alas, you cannot set the NUMERIC TEXT: TEXT property to an arbitrary string: it'll just ignore you.  That's why they used a child object, I bet: it performs specific things (numeric validation) on top of the generic behavior of the TEXT container.
Steve Bird
Culverson.com
LinkedIn
Message 6 of 10
(5,565 Views)
I chased that game around for while.
Solution = very large hammer.
I created a box the right color for the blank field
I wanted, and set it to be the frontmost. Setting and clearing the
visability did the trick.  VERY KKKRUDE,  but it worked.
Thank for your help
Message 7 of 10
(5,562 Views)
Yes, we all have to get crude now and then.
Notice that the numeric control/indicator will actually own THREE of the text containers:
One generic one for the caption.
One generic one for the label.
One numeric-style one for the actual value.
Steve Bird
Culverson.com
LinkedIn
Message 8 of 10
(5,558 Views)
Here is my current kludge to blank a numeric indicator:
Message 9 of 10
(5,547 Views)
Yeah, that works and I've done that too.  I'd like something that works thru the DATA side, though.
That idea, and the one I looked at above, both use PROPERTIES, meaning that I can't use strict TYPEDEFS, and you can't use them in arrays.
Steve Bird
Culverson.com
LinkedIn
Message 10 of 10
(5,528 Views)
