Changing Path file with iterations over loop
 Hi there -- I need some help with changing a file name with every iteration of a for loop, eg;
Iteration 1, file path = iteration1.lvm
Iteration 2, file path = iteration2.lvm
etc
etc...
I've attached a picture of the loop and the file name, along with the vi.
Please help!
(3,568 Views)
Hi Maryam,
for one solution see the attached picture. In the Express vi which you are use, you can use the option to automatically create new filenames if the connected filename already exists.
Mike
Message Edited by MikeS81 on 04-10-2008 02:09 PM
(3,567 Views)
Hi Maryam,
please don't attach BMP pictures here, they take very long to upload/download... And just renaming to *.png doesn't change the fileformat, you have to save it as PNGSmiley Wink
(3,559 Views)
