Changing System Time Affects Network-Published Shared Variable
Hi
I have some network-published shared variable which are acquired in one computer (PC-1) and shown in another computer (PC-2). These variables are aliasing with each other using PSP. When I change the system time of PC-1 backward for one minute, the update rate of variable in PC-2 is decreased for a one minute. Why? Does changing system time affect network-published shared variables? It noteworthy that changing time forward does not have this effect.
Regards
(3,652 Views)
If the system time is used to determine when to send the updates, that would make sense.
1. Send Update
2. Set time to send update to Now+X seconds
2.5 Time got set back a minute
3. X seconds after 2, the time is still less than update, so wait
4. Repeat 3 every X seconds until system time greater or equal to update time, which will actually be X+60 seconds (due to the 1 minute change).
(3,646 Views)
Thanks for your quick replay.
I do not use the system time to determine when to send the updates.
I just used a standard network-published shared variable without any buffer or RT FIFO.
Does SVE use the system time?
(3,629 Views)
That is my current theory.  Somebody from within NI will have to chime in to say for sure.  But the evidence does point to that.
(3,610 Views)
