Changing TestStand report options in Labview
I am currently making a soft calling a TestStand Sequence from Labview. The goal is to modify the report options directly in Labview, and I am not finding the way to do it. I was able for example to log in TestStand with the user I want, add the user if he does not exist...
But changing the report options, impossible!
I have the application Manager (so the Engine) reference plus the SequenceFileViewManager and the ExecutionFileViewManager references (like in the Full and Simple Labview interfaces furnished with TestStand)
Do you have a clue to do it?
I am currently making a soft calling a TestStand Sequence from Labview. The goal is to modify the report options directly in Labview, and I am not finding the way to do it. I was able for example to log in TestStand with the user I want, add the user if he does not exist...But changing the report options, impossible!
(2,881 Views)
(2,859 Views)
