Changing X Axis of a Waveform Chart to Seconds
Hello NI community,
I am relatively new to labVIEW, and I am attempting to make a closed-loop control program to control the velocity of a linear actuator. One issue that I am having is that the X Axis of my waveform charts are not in seconds. I would like to have the charts in terms of elapsed seconds so that I can compare the estimated velocity of the actuator (mm/s) to taking the difference in a potentiometer position reading over the elapsed time (mm/dt) as a sanity check. Right now the X axis seems to relate to time, however it is not the true elapsed time. Any pointers as to how to get the X axis in true relative time?
Thanks! (program attached below)
(3,249 Views)
A waveform *chart* doesn't have a notion of "time history" as it's just a collection of points. Think of it as an array. A waveform *graph* can display X/Y data. I almost always use graphs as I find it easier to manually handle my time data, and the waveform data type is very easy to use. Use "Build waveform" and set the Y array to your accumulated data and the dt to your time period. Note you'll need to manually keep track of your accumulated data instead of feeding it one point at a time.
If you don't want to do that, here are a couple more options you could modify to suit your needs:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHcoCAG&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGxCCAW&l=en-US
Last, you could always right click and go to "Properties" then "Scales" then "Time (X-Axis)" then modify the Scaling Factor Multiplier to something that makes sense. For example, if your sample rate is 10 Hz, then set your scale factor to 1/10 or 0.1.
(3,243 Views)
I'm going to go with the obvious first.  Since you said Waveform Chart you should have a known dt.  Did you format the x axis scale as relative time?
(3,239 Views)
I've tried relative time and floating point, but it still isn't the true time.
(3,232 Views)
Thanks for your response. I've thought about trying to use a property node and scaling the X axis, but i want a definite conversion, not something that I try and do guess and check on. I may look in to using a graph instead. What block should I use to create the X axis as time? And one thing that is convenient is to monitor the chart in real time, but I think I may try and do both.
(3,229 Views)
You can monitor a graph in real time, just accumulate the data and plot it to the chart once every so often. Keep the old data in a shift register.
And scaling the X axis isn't guess and check. You set the scale factor to 1/dt and it's exactly right (assuming, of course, that your sample rate is known and constant). If it's not constant, you probably shouldn't use a chart anyway, but you can kind of "cheat it" a little with this trick:
(3,194 Views)
Thanks for the reply, kind of a stupid question here, but how can i check the sampling rate? I saw in one of the links about using a DAQmx "Sample clock" and a property node, but is there a more basic way to check or obtain that info?
(3,189 Views)
